Bird_phetch
เข้าร่วม: 23 เมษา 2013
ตอบ: 535
ได้รับคำขอบคุณ: 543
ให้คำขอบคุณ: 61
ศุกร์, 6 ธันวา 2013 13:13 - มีใครเคยลองเสริมยางแท่นเครื่องด้วย urethane มั่งครับ
 พอดีหาข้อมูลอยู่
มีสองที
http://www.8thcivic.com/forums/diy-honda-civic-engine/213243-diy-torque-mount-injection.html
อีกแบบ
http://www.energysuspensionparts.com/About-How-to-Make-Universal-Motor-Mount-Inserts.asp
Materials Needed:
3M Window Weld (one tube)
Caulking Gun
Cardboard (an old box or something)
Razor Knife
Sharpie
Rubber Gloves
Hammer
Electrical Tape
Scissors
Begin by washing the mounts to be injected. I used a dish washing brush and some Dawn dish soap. Let them dry thoroughly. Now clear a work space and lay out your materials.
Put some gloves on.
Get your cardboard and razor knife ready.
Now set your first mount on top of the cardboard (leave room for the others) and trace around it with your sharpie.
Before you move the mount off the cardboard, hit the center metal part of it a couple times with the hammer. This is make an imprint in the cardboard which will show you exactly where to cut.
Imprint:
Now cut the cardboard. Cut out the center first.
Using scissors, remove the cardboard piece.
Now press the backing you just made on to one side of the mount.
To hold it in place, use the electrical tape.
Some people say you only need the above 2 pieces, but I completely covered mine.
Now that was exhausting. Time for some refreshment! :dance:
So far we have completed the backing process on one mount (the top 'dog bone' in this case). Now you need to repeat the process on the other 2 mounts (the bottom 'dog bone' and the front torque mount). I will omit commentary on this part.
Now as for the front mount, it cannot be hit with a hammer because of it's shape.
You will need to insert the sharpie into the middle of the mount and draw the center circle to be cut out.
It should look like this:
Now continue the process just we did earlier.
Here are all three torque mounts with cardboard backings in place, taped up and ready to be injected.
Flip them over and place them on a few pieces of paper towel.
Grab your 3M Window Weld and your caulking gun.
Remove the bottom cover on the caulking tube, puncture the business end, install the applicator tip and cut it to size (not too small now).
Now, begin injecting the mounts. Stick the tip all the way in the mount, down to the cardboard.
Fill up one side and then switch to the other. Make sure to be slow and try not to create any air bubbles.
Make sure to fill the mount right up, but not over the sides of the mount or the center metal bolt hole.
Move on to the next mount and replicate the process.
Now all three are filled. Next you have to smooth out the Window Weld with your gloved finger.
Here is a mount with the filling smoothed out:
Here are all three:
Now remove the tape and cardboard backing. Do this slowly, as it will make a mess.
As you can see below, underneath the backing the Window Weld will be a bit messy. You will need to clean it up by adding more filler and smoothing it out.
After smoothing the side where the cardboard was, both sides of each mount should look like this:
Now put them in a safe location and let them cure for 3 days. I have heard many different recommendations for curing time, but 3 days seems to be middle of the road. I moved them from this bench into the sun to make sure they got some heat.
Once cured, follow any of the multiple threads on this forum regarding installation.
[img]"http://www.8thcivic.com/forums/do-yourself-articles/186519-innovative-motor-mounts-diy.html?highlight=mount"]Innovative Motor Mounts DIY[/url]
[img]"http://cms.skunk2.com/id/190/06-CIVIC-SI-SOLID-ENGINE-MOUNT-HOW-TO/4/"]Skunk2 Racing: '06+ CIVIC SI SOLID ENGINE MOUNT HOW-TO[/url]
[img]"http://www.8thcivic.com/forums/do-yourself-articles/90404-ongoing-diy-motor-mount-injection-inserts.html#post2632745"]Ongoing DIY: Motor Mount Injection/Inserts[/url]
etc..
If I have given any misleading information, please feel free to correct me.
Remember after changing your mounts to torque their bolts properly. Thank you asdf:
Here is a picture of the above information:
ได้รับคำขอบคุณจาก: bhumipat  domziia
Jed_Ped
เข้าร่วม: 26 ตุลา 2013
ตอบ: 199
ได้รับคำขอบคุณ: 198
ศุกร์, 6 ธันวา 2013 13:55 - มีใครเคยลองเสริมยางแท่นเครื่องด้วย urethane มั่งครับ
khajohndech
ชื่อเล่น: ต่าย
เข้าร่วม: 14 สิงหา 2012
ตอบ: 75
ได้รับคำขอบคุณ: 50
ให้คำขอบคุณ: 213
ที่อยู่: พระราม3- ถนนตก
ศุกร์, 6 ธันวา 2013 14:07 - มีใครเคยลองเสริมยางแท่นเครื่องด้วย urethane มั่งครับ
somchai10
เข้าร่วม: 08 มิถุนา 2010
ตอบ: 1663
ได้รับคำขอบคุณ: 488
ให้คำขอบคุณ: 103
ศุกร์, 6 ธันวา 2013 19:47 - มีใครเคยลองเสริมยางแท่นเครื่องด้วย urethane มั่งครับ
Tod_Kurono
เข้าร่วม: 26 พฤศจิกา 2013
ตอบ: 124
ได้รับคำขอบคุณ: 104
ให้คำขอบคุณ: 40
ที่อยู่: กทม
ศุกร์, 6 ธันวา 2013 21:00 - มีใครเคยลองเสริมยางแท่นเครื่องด้วย urethane มั่งครับ
อีกนิดตอนปาดรอบๆให้เรียบใช้ ซันไลต์ แตะนิ้วจะสวยขึ้นครับ
nooduean_69
ชื่อเล่น: นู๋เดือน
เข้าร่วม: 04 ตุลา 2011
ตอบ: 1224
ได้รับคำขอบคุณ: 1496
ให้คำขอบคุณ: 3195
ที่อยู่: Minburi
เสาร์, 7 ธันวา 2013 14:06 - มีใครเคยลองเสริมยางแท่นเครื่องด้วย urethane มั่งครับ
แล้วมันจะช่วยเรื่อไรหรอค้ะ (ไม่รู้จิงๆๆนะเนี่ย)
bee@es
เข้าร่วม: 15 กรกฎา 2009
ตอบ: 532
ได้รับคำขอบคุณ: 469
ที่อยู่: korat
เสาร์, 7 ธันวา 2013 14:20 - มีใครเคยลองเสริมยางแท่นเครื่องด้วย urethane มั่งครับ
nooduean_69 พิมพ์ว่า:
ช่วยยืดอายุการใช้ให้นานขึ้นครับ
nong_fb
ชื่อเล่น: ภพ
เข้าร่วม: 15 มีนา 2013
ตอบ: 378
ได้รับคำขอบคุณ: 306
ให้คำขอบคุณ: 216
เสาร์, 7 ธันวา 2013 14:59 - มีใครเคยลองเสริมยางแท่นเครื่องด้วย urethane มั่งครับ
Bird_phetch
ตอบ: 535
ได้รับคำขอบคุณ: 543
ให้คำขอบคุณ: 61
เสาร์, 7 ธันวา 2013 15:12 - มีใครเคยลองเสริมยางแท่นเครื่องด้วย urethane มั่งครับ
Tod_Kurono พิมพ์ว่า:
วันนี้ซื้อของมาทำล่ะ  ที่จินตนาการไว้
 คือจะทำให้แท่นเครื่องเดิม มีการให้ตัวน้อยลง และการสั่นสะเทือนจะเข้ามาในรถมากขึ้น
 แต่เมื่อตัวเครื่องยนต์ขยับได้น้อยลงกำลังก็จะลงไปที่เพลาและล้อได้ดีขึ้น
แต่จุดประสงค์หลักที่อยากจะได้คืือยางแท่นเครื่องทนทานขึ้นในราคาประหยัด 200บาท - 300 บาทกับอุปกรณ์
แต่ก็แลกมาด้วยความสั่นสะเทือน ในห้องโดยสาร
boyboom_16
ตอบ: 4179
ได้รับคำขอบคุณ: 1559
ให้คำขอบคุณ: 4849
เสาร์, 7 ธันวา 2013 16:40 - มีใครเคยลองเสริมยางแท่นเครื่องด้วย urethane มั่งครับ
Bird_phetch พิมพ์ว่า:
ถ้าทำตามที่เค้าDIYก้อโอเคนะคับ ลดการให้ตัวลดแต่ยังไม่น่าแข็งเท่าพวกยูรีเทนแท้ๆแน่ ทำเสร็จแล้วไงมาบอกความรุสึกหน่อยคับ
bhumipat
ชื่อเล่น: รุจ
เข้าร่วม: 27 พฤษภาคม 2009
ตอบ: 1209
ได้รับคำขอบคุณ: 876
ให้คำขอบคุณ: 3608
ที่อยู่: คลอง2 ปทุมธานี
เสาร์, 7 ธันวา 2013 17:59 - มีใครเคยลองเสริมยางแท่นเครื่องด้วย urethane มั่งครับ
