เทียบข้อมูลเลย
D17 Series Engines (1.7 Liters)
Found in:
D17A 2001-2005 (Japan) honda civic
Displacement : 1,668 cc (101.8 cu in)
Bore and Stroke: 75 × 94.4 mm (3.0 × 3.72 in)
Valvetrain : SOHC VTEC (4 valves per cylinder)
Power : [lean burn] 115 hp (85.8 kW, 117 ps) @ ? rpm; 130 hp (96.9 kW, 132 ps) @ ? rpm
Torque : ? ft·lbf (? kg/m, ? Nm) @ ? rpm
[edit] D17A1
Found in:
2001-2005 Honda Civic DX/LX/VP
Bore and Stroke : 75 × 94.4 mm (3.0 × 3.72 in)
Compression : 9.5:1
Power : 115 hp (85.8 kW, 117 ps) @ 6100 rpm
Torque : 110 ft·lbf (15.2 kg/m, 149 Nm) @ 4500 rpm
RPM redline: 6750 rpm
Rev-limiter : 7200 rpm
Valvetrain : SOHC (4 valves per cylinder)
Fuel Control : OBD-2 MPFI
[edit] D17A2
VTEC
Found in:
2001-2005 Honda Civic EX (US only)
2001-2005 Honda Civic LX (Europe)
2001-2005 Honda Civic Si (Canada only)
2001-2005 Acura 1.7 EL (Canada only)
2000-2007 Honda Stream 1.7 (Japan)
Bore and Stroke : 74.98 × 94.4 mm (2.952 × 3.72 in)
Rod Length : 137 mm
Rod/Stroke : 1.48
Compression : 9.9:1
Power : 127 hp (94.7 kW, 132 ps) @ 6300 rpm
Torque : 114 ft·lbf (114 ft·lbf USDM[3]) (15.8 kg/m, 155 Nm) @ 4800 rpm
RPM redline: 6800 rpm
VTEC Switchover : 4500 rpm
[edit] D17A6
VTEC-E
Found in:
2001-2005 Honda Civic HX
Compression : 9.9:1
Power : 117 hp (93.2 kW, 127 ps) @ 6100 rpm[4]
Torque : 111 ft·lbf (15.3 kg/m, 150 Nm) @ 4500 rpm
Valvetrain : SOHC VTEC-E Lean Burn (4 valves per cylinder)
VTEC Switchover : 2300
[edit] D17A7
Found in:
2001-2005 Honda Civic GX
Fuel CNG (Compressed Natural Gas)
Compression : 12.5:1
Power : 100 hp (74.6 kW, 101 ps) @ 6100 rpm
Torque : 98 ft·lbf (13.5 kg/m, 133 Nm) @ 4000 rpm
Valvetrain : SOHC (? valves per cylinder)
ตอนนี้ผมใช้
D16W7
VTEC-E
Found in:
2005-2007 Honda Civic Vti-L/ Vti (Asia)
Displacement:1,590 cc (97 cu in)
Compression : 10.9:1
Power : 115 hp (85.8 kW, 117 ps) @ 5600 rpm
Torque : 112 ft·lbf (15.5 kg/m, 152 Nm) @ 4300 rpm
Redline : 6100 rpm
Limit : 6200 rpm
Fuel Control : OBD-1 MPFI
ECU Code : PM12
Also found in 2001-2005 Honda Civic ES (Europe)
Same as above, except:
Power: 110 hp (82.0 kW, 81 kW) @ 5600 rpm
Redline 6100 rpm
Limit 6200 rpm
D16W7
* Vtec-E
* Found in:
o 2005-2007 Honda Civic Vti-L/ Vti (Singapore)
+ Displacement:1590 cm3
+ Compression : 10.9:1
+ Power : (*160) hp (130 kW) @ 7800 rpm & 108 ft·lbf @ 7900 rpm
+ Valvetrain : SOHC
+ Redline 8600RPM
+ Limit 8900RPM
+ Fuel Control : OBD-1 MPFI
+ ECU Code: PM12
***Singapore***หาอยากมากลูกสูบไม่เหมือนชาวบ้านกล่องเปิดรอบได้มากทีเดียวและแคมก็สูงกว่าปกติด้วย ผมได้มาไม่ได้กล่องมาใช้กล่องเดิมได้แค่ 7200rpm เท่านั้นเองแรงม้าไม่รู้
cc น้อยวิ้งก็เท่ากับ cc
