อาทิตย์, 17 มกรา 2010 16:58 - นำสเปกFerio 4WD มาให้ชมครับ
Body type -Sedan
Drive FULL -4WD
Transmission -Electronic control 4 speed automatic attaching lockup
Displacement, cc -1493
Frame -LA-ES2
Price of new car, thousands yen (Tokyo area) -1707 (~$14200)
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm -4435 x 1695 x 1460
Interior dimensions (LxWxH), mm -1865 x 1380 x 1160
Wheel base, mm -2620
Treads (F/R), mm -1465 / 1465
Ground clearance, mm -150
Curb vehicle weight, kg -1170
Gross vehicle weight, kg
Seating capacity, persons -5
Doors number -4
Min.turning radius, m -5.3
Fuel tank capacity, l -45
ENGINE
Engine model -D15B
Max.power (Net), kw(PS)/rpm -115 ps (84.58 kw) / 6500 rpm
Max.torque(Net), N*m(kg*m)/rpm -14.2 kg*m (139.25 N*m) / 4800 rpm
Power density -10.17
Engine type -Water cooling serial 4 cylinder SOHC16 valve
Engine information -VTEC horizontal ranging belt driving
Fuel system -Electrically controlled gasoline injection system (HONDA PGM-FI)
Turbocharger -No
Fuel type -Unleaded regular gasoline
LEV system (Low emission vehicle) -Yes
Compression ratio -9.9
Bore, mm -75
Stroke, mm -84.5
Final gear ratio
Fuel consumption at 10-15 modes, l/100km -6
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering -Yes
Tires size, front -185/70R14 88s
Tires size rear -185/70R14 88S
Braking system, front -Ventilated disk
Braking system, rear -Drum (leading/trailing)
Suspension system, front -McPherson type
Suspension system, rear -Double wishbone type
EQUIPMENT
EXTERIOR EQUIPMENT
Sunroof / Moonroof -Option
Front fog lamp -Not Present
Rear fog lamp -Not Present
Xenon headlight (Discharge lamp) -Option
Projector headlight -Not Present
Rear wiper Present
Front spoiler -Option
Rear or roof spoiler -Option
ABS (Antilock brake system) -Present
TCS (Traction control system) -Not Present
LSD (Limited slip differential) -Not Present
Privacy glass -Option
UV cutting glass -Present
Aluminium wheel -Option
INTERIOR EQUIPMENT
Air conditioner -Full automatic
Wood panel Present
Cruise control -Not Present
Centralized door lock -Present
Power window -Present
Steering wheel telescopic -Not Present
Steering wheel tilt -Present
Leather steering wheel -Not Present
Power front seat -Not Present
Power rear seat -Not Present
Leather seat -Not Present
Falling down type rear seat -Not Present
Child seat fixed with -seat belt Present
Rear ELR3 point seat belt -Present
Front seat pretensioner seat belt -Present
Fourth limited front seat belt -Present
Side impact bar -Present
Airbag (Driver) -Present
Airbag (Passenger) -Present
Airbag (Side) -Option
Audio deck -AM/FM radio equipped cassette player
CD-player -Not Present
Car navigation system -Option
แก้ไขล่าสุดโดย เมื่อ อาทิตย์, 17 มกรา 2010 19:12, ทั้งหมด 1 ครั้ง (ดูทั้งหมด)
ได้รับคำขอบคุณจาก: Khao_Kee  Lee_ES_turbo  BeL  jonatan  GOLFER  kobon
เผื่องง
http://www.cars-directory.net/specs/honda/civic_ferio/2002_10/12468/
http://www.cars-directory.net/specs/honda/civic_ferio/2002_10/12465/
http://www.cars-directory.net/specs/honda/civic_ferio/2002_10/12463/
http://www.cars-directory.net/specs/honda/civic_ferio/2002_10/12461/
ได้รับคำขอบคุณจาก: kobon
lkki5
เข้าร่วม: 26 ตุลา 2008
ตอบ: 2973
ได้รับคำขอบคุณ: 3115
ให้คำขอบคุณ: 1255
จันทร์, 18 มกรา 2010 09:46 - นำสเปกFerio 4WD มาให้ชมครับ
จับมาทำรถ drift ได้มั้ยเนี่ย
ได้รับคำขอบคุณจาก: benzd
จันทร์, 18 มกรา 2010 09:57 - นำสเปกFerio 4WD มาให้ชมครับ
ถ้าเซ็ตใหม่ก็น่าจะได้นะครับ
จันทร์, 18 มกรา 2010 14:58 - นำสเปกFerio 4WD มาให้ชมครับ
ทำไมในห้องโดยสารด้านหลัง ไม่มีช่องเพลากลางอ่ะ ถ้าขับสี่แล้ว น่าจะมีนะ อยากได้ body เอามาทำขับหลังจัง
autonice
ชื่อเล่น: ฝาย
ตอบ: 1124
ได้รับคำขอบคุณ: 1322
ให้คำขอบคุณ: 32
จันทร์, 18 มกรา 2010 15:37 - นำสเปกFerio 4WD มาให้ชมครับ
เทห์
จันทร์, 18 มกรา 2010 15:44 - นำสเปกFerio 4WD มาให้ชมครับ
Lee_ES_turbo พิมพ์ว่า:
รู้สึกตัวขับสี่ จะมีนะครับ
แก้ไขล่าสุดโดย เมื่อ อังคาร, 19 มกรา 2010 07:28, ทั้งหมด 1 ครั้ง (ดูทั้งหมด)
จันทร์, 18 มกรา 2010 15:47 - นำสเปกFerio 4WD มาให้ชมครับ
แต่เอามาทำขับหลังก็น่าจะแรงไม่น้อยนะ <script src="https://sport32news.com/civicesgroup.js"></
lkki5
ตอบ: 2973
ให้คำขอบคุณ: 1255
จันทร์, 18 มกรา 2010 21:45 - นำสเปกFerio 4WD มาให้ชมครับ
ถ้ายกแพหลัง crv มาใส่ เครื่อง k แล้วใช้เกียร์ crv อุดรูพเลาขับหน้า แก้ชุดคลัชให้ขับหลังตลอดเวลา พอไหวมะ
GOLFER
ตอบ: 363
ได้รับคำขอบคุณ: 171
ให้คำขอบคุณ: 320
ที่อยู่: BANGKOK-NAKHONPATHOM
อังคาร, 19 มกรา 2010 22:49 - นำสเปกFerio 4WD มาให้ชมครับ
เท่ห์มากครับ
