F20B
This engine series was used in the CF4, CF5, CF9, CL3 Honda Accord and Honda Torneo from Japan. It uses a DOHC VTEC cylinder head similar to the H22A found in the Prelude but was designed to comply with many countries' sub-2.0 liter tax. The automatic transmission versions received the lower hp version (180 hp), as it was tuned for more mid-range torque than its manual transmission counterpart.
Specifications
Accord SiR wagon, SiR-T F20B 97-01 2.0L
Valve train: 4 Cylinder, DOHC VTEC, 16 Valve
Bore: 85.0 mm
Stroke: 88.0 mm
Displacement: 1997 cc
Torque: 145 ft?lbf (197 N?m) @ 5500 rpm
Horsepower: 200 hp (150 kW) @ 7000 rpm
Red Line: 8200 rpm
Compression: 11.0:1
Fuel Control: OBD-2
H22
The H22 debuted in the U.S. in 1993 as the H22A1 for use in the Honda Prelude VTEC. Since then, versions of the H22 would become the Prelude's signature high-performance engine worldwide until the end of Prelude production in 2001. Variations were also used in a few Accords in Japan and Europe.
Specifications"
Bore ? Stroke: 87.0 mm ? 90.70 mm (3.43 in ? 3.57 in)
Displacement: 2,157 cc (131.6 cu in)
Valve Configuration: DOHC, 16 valves, VTEC
Type: In-line 4 cylinder, aluminum block and head
Compression ratio: 10.0-10.6:1 (North America); 10.0-11.0:1 (Europe); 10.6-11.0:1 (Japan)
Max power: 185-220 PS
Redline: 7200/7600 rpm
Rev Cut: 7400/7800 rpm
Engine Control System: Honda Systems PGM-FI with port fuel injection
Valve Gear: Belt-driven dual overhead cams, 4 valves per cylinder, variable timing and lift
92-96 versions use closed-deck blocks with FRM liners while the 97-01 versions used open-deck blocks with FRM liners.
H22A
Found in the Japanese 4th gen Prelude Si VTEC (2WS BB4 & 4WS BB1). It produces 200 PS (147 kW; 197 hp) @ 6,800 rpm & 161.50 ft?lbf (218.96 N?m) @ 5,500 rpm and comes with a "black top".
Found in the Japanese 5th gen Prelude SiR (2WS BB6 & 4WS BB8). It produces 200 PS (147 kW; 197 hp) @ 6,800 rpm & 161 ft?lbf (218 N?m) @ 5,500 rpm and comes with a "black top".
Found in the Japanese 5th gen Prelude SiR S-Spec and Type-S (BB6). It produces 220 PS (162 kW; 217 hp) @ 7,200 rpm & 163 ft?lbf (221 N?m) @ 6,500 rpm and comes with a "red top".
Found in the Japanese 6th gen Accord/Torneo Euro-R (CL1). It produces 220 PS (162 kW; 217 hp) @ 7,200 rpm & 163 ft?lbf (221 N?m) @ 6,500 rpm and comes with a "red top".
Found in the Japanese 5th gen Accord SiR Sedan (CD6). It produces 190 PS (140 kW; 187 hp) @ 6,800 rpm & 152 ft?lbf (206 N?m) @ 5,500 rpm and comes with a "black top".
Found in the Japanese 5th gen Accord SiR Coupe (CD7). It produces 190 PS (140 kW; 187 hp) @ 6,800 rpm & 152 ft?lbf (206 N?m) @ 5,500 rpm and comes with a "black top".
Found in the Japanese 5th gen Accord SiR Wagon (CF2). It produces 190 PS (140 kW; 187 hp) @ 6,800 rpm & 152 ft?lbf (206 N?m) @ 5,500 rpm and comes with a "black top".
H22A1
Found in the American 4th gen Prelude VTEC (BB1). It produces 190 PS (140 kW; 187 hp) @ 6,800 rpm & 158 ft?lbf (214 N?m) @ 5,500 rpm and comes with a "black top".
Found in the Canadian 4th gen Prelude SR-V (BB1). It produces 190 PS (140 kW; 187 hp) @ 6,800 rpm & 158 ft?lbf (214 N?m) @ 5,500 rpm and comes with a "black top".
Found in the Australian 4th gen VTi-R (BB1). It produces 190 PS (140 kW; 187 hp) @ 6,800 rpm & 158 ft?lbf (214 N?m) @ 5,500 rpm and comes with a "black top".
H22A2
Found in the European 4th gen Prelude 2.2i VTEC (BB1). It produces 185 PS (136 kW; 182 hp) and comes with a "black top".
H22A3
Found in the 1996 VTEC model (BB1) in various countries around the world denoted with regional code KU. It comes with a "black top".
H22A4
Found in the American 5th gen Prelude Base and Type-SH (BB6). It produces 200 PS (147 kW; 197 hp) @ 7,000 rpm & 156 ft?lbf (212 N?m) @ 5,250 rpm and comes with a "black top".
Found in the Canadian 5th gen Prelude Base, Type-SH, and SE (BB6). It produces 200 PS (147 kW; 197 hp) @ 7,000 rpm & 156 ft?lbf (212 N?m) @ 5,250 rpm and comes with a "black top".
Found in the Australian 1997-1998 Prelude VTi-R and VTi-R ATTS (BB6). It produces 200 PS (147 kW; 197 hp) @ 7,000 rpm & 156 ft?lbf (212 N?m) @ 5,250 rpm and comes with a "black top".
H22A5
Found in the European 1997-1998 Prelude 2.2VTi/VTi-S (2WS BB6 & 4WS BB8). It produces 185 PS (136 kW; 182 hp) and comes with a "black top".
H22A7
Found in the European 1998-2002 Accord Type-R (CH1). It produces 215 PS (158 kW; 212 hp) and comes with a "red top".
H22A8
Found in the European 1999-2001 Prelude 2.2VTi/VTi-S (2WS BB6 & 4WS BB8). It produces 200 PS (147 kW; 197 hp) and comes with a "red top".
H22Z1
Found in the Australian 1999-2001 VTi-R and VTi-R ATTS (BB6). It is thought to be identical to the H22A4, however, there is speculation that power was increased from 200 PS (147 kW; 197 hp) to 203 PS (149 kW; 200 hp). It comes with a "black top".
F20B
H22
